Segmenting Objects through an Autonomous Agnostic Exploration Conducted by a Robot - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Human's everyday environment is an open environment in which objects with new shapes, colors or textures frequently appear. Enabling robots to deal with such environments and to manipulate those objects raises a difficult challenge: how to recognize an object ? How to distinguish it from the background ? An approach is proposed here to allow the robot to find this segmentation on its own. It relies on an active exploration of the environment aimed at identifying features of things that move after a contact with robot's end-effector. The only assumption made is that objects of interest are solid objects that the robot can move. The proposed approach can thus be applied without modifications to a large range of environments, as shown by the experiments performed by the robot.
2017INVI3907.pdf (22.18 Mo) Télécharger le fichier
hal-01879084 , version 1 (21-09-2018)
Leni Le Goff, Ghanim Mukhtar, Pierre-Henri Le Fur, Stephane Doncieux. Segmenting Objects through an Autonomous Agnostic Exploration Conducted by a Robot. 2017 First IEEE International Conference on Robotic Computing (IRC), Apr 2017, Taichung, Taiwan. ⟨10.1109/IRC.2017.22⟩. ⟨hal-01879084⟩
79 Consultations
39 Téléchargements
