Programming Dynamic Reconfigurable Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Rim El Ballouli
  • Fonction : Auteur
Saddek Bensalem
Marius Bozga
Joseph Sifakis
  • Fonction : Auteur
DR-BIP is an extension of the BIP component framework intended for programming reconfigurable systems encompassing various aspects of dynamism. It relies on architectural motifs to structure the architecture of a system and to coordinate its reconfiguration at run-time. An architectural motif defines a set of interacting components that evolve according to reconfiguration rules. With DR-BIP, the dynamism can be captured as the interplay of dynamic changes in three independent directions 1) the organization of interactions between instances of components in a given configuration; 2) the reconfiguration mechanisms allowing creation/deletion of components and management of their interaction according to a given architectural motif; 3) the migration of components between predefined architectural motifs which characterizes dynamic execution environments. The paper lays down the formal foundation of DR-BIP, illustrates its expressiveness on few examples and discusses avenues for dynamic reconfigurable system design.
main.pdf (392.68 Ko) Télécharger le fichier
hal-01888550 , version 1 (05-10-2018)
  • HAL Id : hal-01888550 , version 1
Rim El Ballouli, Saddek Bensalem, Marius Bozga, Joseph Sifakis. Programming Dynamic Reconfigurable Systems. Formal Aspects of Component Software - 15th International Conference, FACS 2018, Oct 2018, Pohang, South Korea. ⟨hal-01888550⟩
73 Consultations
269 Téléchargements
