Dissipativity based stability criterion for aperiodic sampled-data systems subject to time-delay - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
This extended abstract presents a dissipativity-based stability analysis of Linear Time Invariant (LTI) systems subjected to aperiodic sampling and time-varying delay. We provide a novel stability criterion which aids in making the trade-offs between maximum allowable sampling interval and delays while guaranteeing stability. Simulation results have been provided to demonstrate the effectiveness of the proposed criterion.
Automatique
CHAOS Final.pdf (430.72 Ko) Télécharger le fichier
hal-01893534 , version 1 (24-10-2019)
  • HAL Id : hal-01893534 , version 1
Jijju Thomas, Christophe Fiter, Laurentiu Hetel, Nathan van de Wouw, Jean-Pierre Richard. Dissipativity based stability criterion for aperiodic sampled-data systems subject to time-delay. 5th IFAC Conference on Analysis and Control of Chaotic Systems (CHAOS), Oct 2018, Eindhoven, Netherlands. ⟨hal-01893534⟩
125 Consultations
83 Téléchargements
