MCC’2017 - The Seventh Model Checking Contest - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Proceedings/Recueil Des Communications LNCS Transactions on Petri Nets and Other Models of Concurrency Année : 2018
Fabrice Kordon
Hugues Evrard
  • Fonction : Auteur
  • PersonId : 961729
Yann Thierry-Mieg
Jaco van de Pol
Created in 2011, the Model Checking Contest (MCC) is an annual competition dedicated to provide a fair evaluation of software tools that verify concurrent systems using state-space exploration techniques and model checking. This article presents the principles and results of the 2017 edition of the MCC, which took place along with the Petri Net and ACSD joint conferences in Zaragoza, Spain.
ToPNoC-mcc2017.pdf (526.86 Ko) Télécharger le fichier
hal-01917492 , version 1 (13-11-2018)
Fabrice Kordon, Hubert Garavel, Lom Hillah, Emmanuel Paviot-Adet, Loïg Jezequel, et al.. MCC’2017 - The Seventh Model Checking Contest. LNCS Transactions on Petri Nets and Other Models of Concurrency, 11090, pp.181-209, 2018, Lecture Notes in Computer Science, ⟨10.1007/978-3-662-58381-4_9⟩. ⟨hal-01917492⟩
534 Consultations
566 Téléchargements
