Faster arbitrary-precision dot product and matrix multiplication - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
Fredrik Johansson
  • Fonction : Auteur
  • PersonId : 1008347
We present algorithms for real and complex dot product and matrix multiplication in arbitrary-precision floating-point and ball arithmetic. A low-overhead dot product is implemented on the level of GMP limb arrays; it is about twice as fast as previous code in MPFR and Arb at precision up to several hundred bits. Up to 128 bits, it is 3-4 times as fast, costing 20-30 cycles per term for floating-point evaluation and 40-50 cycles per term for balls. We handle large matrix multiplications even more efficiently via blocks of scaled integer matrices. The new methods are implemented in Arb and significantly speed up polynomial operations and linear algebra.
matrix.pdf (373.28 Ko) Télécharger le fichier
hal-01980399 , version 1 (14-01-2019)
hal-01980399 , version 2 (09-05-2019)
Fredrik Johansson. Faster arbitrary-precision dot product and matrix multiplication. 2019. ⟨hal-01980399v1⟩
240 Consultations
433 Téléchargements
