A comparative study of models to predict storm impact on beaches - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Natural Hazards Année : 2017
The storm impact scale of Sallenger (J Coast Res 890-895, 2000) was tested on a partially engineered beach. This scale is supposed to provide a convenient tool for coastal managers to categorize the storm impact at the shore. It is based on the relation between the elevation of storm wave runup and the elevation of a critical geomorphic or man-made structures in the present study. Two different approaches were tested to estimate the elevation of extreme storm wave runup: (1) a parametric model based on offshore wave conditions and local beach slope and (2) the XBeach process-based model that solves implicitly the runup. The study shows comparisons between impact regimes computed with the two methods and those derived from video observations acquired during 2 weeks while the site was battered by three consecutive storms. Storms scenario including wave conditions with higher return periods and different tidal range were also investigated. The advantages and disadvantages of the two methods used to compute extreme water level are then compared, and guidelines for the development of early warning system are drawn.
de Santiago_2017_A comparative study of models to predict storm impact.pdf (1.88 Mo) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-02058605 , version 1 (06-03-2019)
Iñaki de Santiago, Denis Morichon, Stéphane Abadie, J H M Reniers, Pedro Liria. A comparative study of models to predict storm impact on beaches. Natural Hazards, 2017, 87 (2), pp.843-865. ⟨10.1007/s11069-017-2830-6⟩. ⟨hal-02058605⟩
Collections
UNIV-PAU SIAME
79 Consultations
289 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
