Brilliant Sm, Eu, Tb, and Dy Chiral Lanthanide Complexes with Strong Circularly Polarized Luminescence - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of the American Chemical Society Année : 2007
Gilles Muller
  • Fonction : Auteur
Evan Moore
  • Fonction : Auteur
Jide Xu
  • Fonction : Auteur
Jurek Sokolnicki
  • Fonction : Auteur
James Riehl
  • Fonction : Auteur
Uyen Le
  • Fonction : Auteur
Seth Cohen
  • Fonction : Auteur
Kenneth Raymond
  • Fonction : Auteur
The synthesis, characterization, and luminescent behavior of trivalent Sm, Eu, Dy, and Tb complexes of two enantiomeric, octadentate, chiral, 2-hydroxyisophthalamide ligands are reported. These complexes are highly luminescent in solution. Functionalization of the achiral parent ligand with a chiral 1-phenylethylamine substituent on the open face of the complex in close proximity to the metal center yields complexes with strong circularly polarized luminescence (CPL) activity. This appears to be the first example of a system utilizing the same ligand architecture to sensitize four different lanthanide cations and display CPL activity. The luminescence dissymmetry factor, g(lum), recorded for the Eu(III) complex is one of the highest values reported, and this is the first time the CPL effect has been demonstrated for a Sm(III) complex with a chiral ligand. The combination of high luminescence intensity with CPL activity should enable new bioanalytical applications of macromolecules in chiral environments.
Chimie
hal-02090687 , version 1 (05-04-2019)
Stephane Petoud, Gilles Muller, Evan Moore, Jide Xu, Jurek Sokolnicki, et al.. Brilliant Sm, Eu, Tb, and Dy Chiral Lanthanide Complexes with Strong Circularly Polarized Luminescence. Journal of the American Chemical Society, 2007, 129 (1), pp.77-83. ⟨10.1021/ja064902x⟩. ⟨hal-02090687⟩
10 Consultations
0 Téléchargements
