Fascia lata numerical model with discrete element method: relationship between micro and macroscale for tensile tests until rupture - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Numerical models are useful to better understand the mechanical responseof various tissues and materials. With the discrete element method, it is possible to model complex structures with simple elements: small mass elements connected with springs. The macroscopic response of the tissue can then be explained by its microscopic description. We propose to model tensile tests on fascia lata using this method, because of its structure composed of two layersof collagen fibersconnected by a proteoglycan matrix .
ris00001465.pdf (106.97 Ko) Télécharger le fichier
hal-02108398 , version 1 (24-04-2019)
hal-02108398 , version 2 (12-03-2021)
Christophe Muth-Seng, Anthony Roux, Sébastien Laporte, Laure-Lise Gras. Fascia lata numerical model with discrete element method: relationship between micro and macroscale for tensile tests until rupture. Fifth international fascia research congress, Nov 2018, Berlin, Germany. pp. 851-852, ⟨10.1016/j.jbmt.2018.09.020⟩. ⟨hal-02108398v2⟩
56 Consultations
108 Téléchargements
