Low-rank space-time decoupled isogeometric analysis for parabolic problems with varying coefficients
In this paper we present a space-time isogeometric analysis scheme for the discretization of parabolic evolution equations with diffusion coefficients depending on both time and space variables. The problem is considered in a space-time cylinder in R +1 , with = 2, 3 and is discretized using higher-order and highly-smooth spline spaces. This makes the matrix formation task very challenging from a computational point of view. We overcome this problem by introducing a low-rank decoupling of the operator into space and time components. Numerical experiments demonstrate the efficiency of this approach.
spacetime_lowrank.pdf (1.06 Mo)
Télécharger le fichier
Format : Figure, Image
