Reaction Networks to Boolean Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
We study the problem of how to convert reaction networks into boolean networks. We start from the sign abstraction of the ODE semantics of reaction network, and show that it can be captured by a quasi-boolean network, a generalization of boolean networks that we introduce. We then show that any quasi-boolean networks can be converted into a boolean networks by using John’s overapproximation. We then apply a recent rewriting algorithm base on elementary modes to make the linear equation system exact with respect to the boolean abstraction, for improving the precision of the conversion of quasi-boolean to boolean networks, also in the general nonlinear case. Thereby we improve our compiler from reaction networks to boolean networks as well.
1.pdf (447.53 Ko) Télécharger le fichier
hal-02279942 , version 1 (13-05-2020)
hal-02279942 , version 2 (15-05-2020)
hal-02279942 , version 3 (07-05-2021)
hal-02279942 , version 4 (11-05-2021)
hal-02279942 , version 5 (12-05-2021)
hal-02279942 , version 6 (26-07-2021)
hal-02279942 , version 7 (15-09-2021)
hal-02279942 , version 8 (17-05-2022)
hal-02279942 , version 9 (24-06-2022)
  • HAL Id : hal-02279942 , version 5
Emilie Allart, Joachim Niehren, Cristian Versari. Reaction Networks to Boolean Networks. 2021. ⟨hal-02279942v5⟩
583 Consultations
384 Téléchargements
