Governance maturity grid: a transition method for integrating sustainability into companies? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Cleaner Production Année : 2017
System innovation for sustainability requires innovation in corporate governance. Social, ecological, economic, territorial and governance dimensions of sustainability are explored and a set of sustainability principles are integrated into a governance maturity grid. This grid enables both the assessment and the improvement of current strategic and operational practices regarding sustainability. It has been implemented in two industrial companies. As a result, it promotes senior management's reflection on their current strategies regarding value creation systems, and supports them in the definition of their sustainable strategies and the means of achieving them. This study is designed for businesses and presents a tool under development to support organizational innovation for system sustainability.
LISPEN_JCP_2017_ROUCOULES.pdf (1.08 Mo) Télécharger le fichier
hal-02288827 , version 1 (18-09-2019)
  • HAL Id : hal-02288827 , version 1
Romain Allais, Lionel Roucoules, Tatiana Reyes. Governance maturity grid: a transition method for integrating sustainability into companies?. Journal of Cleaner Production, 2017, 140, pp.213-226. ⟨hal-02288827⟩
177 Consultations
519 Téléchargements
