When Deep Learning meets Web Measurements to infer Network Performance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Web browsing remains one of the dominant applications of the internet, so inferring network performance becomes crucial for both users and providers (access and content) so as to be able to identify the root cause of any service degradation. Recent works have proposed several network troubleshooting tools, e.g, NDT, MobiPerf, SpeedTest, Fathom. Yet, these tools are either computationally expensive, less generic or greedy in terms of data consumption. The main purpose of this work is to leverage passive measurements freely available in the browser and machine learning techniques (ML) to infer network performance (e.g., delay, bandwidth and loss rate) without the addition of new measurement overhead. To enable this inference, we propose a framework based on extensive controlled experiments where network configurations are artificially variedand the Web is browsed, then ML is applied to build models that estimate the underlying network performance. In particular, we contrast classical ML techniques (such as random forest) to deep learning models trained using fully connected neural networks and convolutional neural networks (CNN). Results of our experiments show that neural networks have a higher accuracy compared to classical ML approaches. Furthermore, the model accuracy improves considerably using CNN.
1570571952.pdf (850.22 Ko) Télécharger le fichier
hal-02358004 , version 1 (11-11-2019)
Imane Taibi, Yassine Hadjadj-Aoul, Chadi Barakat. When Deep Learning meets Web Measurements to infer Network Performance. CCNC 2020 - IEEE Consumer Communications & Networking Conference, Jan 2020, Las Vegas, United States. pp.1-6, ⟨10.1109/CCNC46108.2020.9045116⟩. ⟨hal-02358004⟩
164 Consultations
462 Téléchargements
