Sufficient Stability Conditions for Time-varying Networks of Telegrapher's Equations or Difference Delay Equations - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Journal Articles SIAM Journal on Mathematical Analysis Year : 2021
We give a sufficient condition for exponential stability of a network of lossless telegrapher's equations, coupled by linear time-varying boundary conditions. The sufficient conditions is in terms of dissipativity of the couplings, which is natural for instance in the context of microwave circuits. Exponential stability is with respect to any $L^p$-norm, $1\leq p\leq\infty$. This also yields a sufficient condition for exponential stability to a special class of linear time-varying difference delay systems which is quite explicit and tractable. One ingredient of the proof is that $L^p$ exponential stability for such difference delay systems is independent of $p$, thereby reproving in a simpler way some results from [3].
200824-papier_stab.pdf (416.92 Ko) Télécharger le fichier
Dates and versions
hal-02385548 , version 1 (28-11-2019)
hal-02385548 , version 2 (24-08-2020)
hal-02385548 , version 3 (19-01-2021)
Identifiers
Cite
Laurent Baratchart, Sébastien Fueyo, Gilles Lebeau, Jean-Baptiste Pomet. Sufficient Stability Conditions for Time-varying Networks of Telegrapher's Equations or Difference Delay Equations. SIAM Journal on Mathematical Analysis, In press. ⟨hal-02385548v2⟩
364 View
377 Download
Share
