The Hoare-fol Tool - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2019
The Hoare-fol Tool
This document presents the tool named "Application of Hoare Logic and Dijkstra's Weakest Proposition Calculus to Biological Regulatory Networks Using Path Programs with Branching First-Order Logic Operators" or Hoare-fol for short. This tool consists in an implementation of the theoretical work developed in [Bernot et al., 2019] and contains the following features: (1) computation of the weakest precondition of a Hoare triple, (2) simplification of this weakest precondition using De Morgan laws and partial knowledge on the initial state, and (3) translation into Answer Set Programming to allow a solving of all compatible solutions.
main.pdf (441.71 Ko) Télécharger le fichier
hal-02409801 , version 1 (17-12-2019)
Maxime Folschette. The Hoare-fol Tool. [Technical Report] Univ. Lille, CNRS, Centrale Lille, UMR 9189 - CRIStAL - Centre de Recherche en Informatique Signal et Automatique de Lille, F-59000 Lille, France. 2019. ⟨hal-02409801⟩
94 Consultations
85 Téléchargements
