Analysis of fibrinogen genes in patients with congenital afibrinogenemia
Several cDNA clones coding for A alpha, B beta and gamma chains of fibrinogen have been isolated from a human liver cDNA library. They were selected by differential hybridization with probes raised against fractionated liver mRNA (positive probes) and muscle and albumin mRNA (negative probes), then firmly identified by positive hybridization selection. Three of these clones, encoding A alpha, B beta and gamma fibrinogen chain sequences, were further characterized by restriction mapping and used as probes to characterize fibrinogen mRNAs from adult and fetal liver and fibrinogen genes in normal individuals and two afibrinogenemic patients. The results indicate that there is a single copy of the fibrinogen genes which are present and grossly intact in afibrinogenemic DNA.
