Stability Analysis for A Class of Linear Hyperbolic System of Balance Laws with Sampled-data Control ⋆ - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The stability for a class of linear hyperbolic systems with distributed sampled-data controllers is discussed in this paper. The original sampled-data system is firstly transformed into a new equivalent system by modelling the sampling induced error as a reset integrator operator. Then we construct an appropriate Lyapunov function and obtain sufficient conditions for the Rε-stability of the system based on linear matrix inequalities (LMIs). A numerical example illustates our results: when the sampling interval is within the allowable range, the solution of the system converges from the domain of attraction to a positive invariant set.
IFAC_1016.pdf (267.19 Ko) Télécharger le fichier
hal-02491857 , version 1 (26-02-2020)
hal-02491857 , version 2 (11-01-2022)
  • HAL Id : hal-02491857 , version 1
Xinyong Wang, Ying Tang, Christophe Fiter, Laurentiu Hetel. Stability Analysis for A Class of Linear Hyperbolic System of Balance Laws with Sampled-data Control ⋆. IFAC World Congress, Jul 2020, Berlin, Germany. ⟨hal-02491857v1⟩
192 Consultations
113 Téléchargements
