A mixed finite element discretization of dynamical optimal transport - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
In this paper we introduce a new class of finite element discretizations of the quadratic optimal transport problem based on its dynamical formulation. These generalize to the finite element setting the finite difference scheme proposed by Papadakis et al. [SIAM J Imaging Sci, 7(1):212–238,2014]. We solve the discrete problem using a proximal-splitting approach and we show how to modify this in the presence of regularization terms which are relevant for imaging applications.
MixedFiniteElementsHAL.pdf (1.93 Mo) Télécharger le fichier
hal-02501634 , version 1 (09-03-2020)
hal-02501634 , version 2 (22-05-2020)
hal-02501634 , version 3 (12-10-2020)
hal-02501634 , version 4 (22-02-2022)
Andrea Natale, Gabriele Todeschi. A mixed finite element discretization of dynamical optimal transport. 2020. ⟨hal-02501634v1⟩
348 Consultations
190 Téléchargements
