Sampled-data Control for a Class of Linear Hyperbolic System via the Lyapunov-Razumikhin Technique - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This work investigates the stability for a class of linear hyperbolic systems with distributed sampled-data controllers. First, we convert the original system into an equivalent system in which the sampling induced error is modeled as a reset integrator. Then by means of an appropriate Lyapunov function coupled with the Razumikhin technique, sufficient conditions are given for the Rε-stability of the system. Finally, our results are validated by a numerical example.
root (3).pdf (197.91 Ko) Télécharger le fichier
hal-02566290 , version 1 (06-05-2020)
hal-02566290 , version 2 (23-03-2021)
hal-02566290 , version 3 (11-01-2022)
  • HAL Id : hal-02566290 , version 2
Xinyong Wang, Christophe Fiter, Ying Tang, Laurentiu Hetel. Sampled-data Control for a Class of Linear Hyperbolic System via the Lyapunov-Razumikhin Technique. European Control Conference 21, Jun 2021, Virtual Conference, Netherlands. ⟨hal-02566290v2⟩
102 Consultations
70 Téléchargements
