Goose hemorrhagic polyomavirus detection in geese using real-time PCR assay - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Avian diseases Année : 2013
Goose hemorrhagic polyomavirus (GHPV) is the viral agent of hemorrhagic nephritis enteritis of geese (HNEG), a lethal disease of goslings. Although death is the most common outcome, geese that recover from HNEG are persistently infected. Here, we present the development of real-time SYBRH Green real-time PCR targeted to GHPV and its use to assess the prevalence of GHPV infection in French geese flocks. When compared with classical end-point PCR, real-time PCR revealed a much better sensitivity and equivalent specificity. Real-time PCR could, therefore, be considered a gold standard for the detection of GHPV. Results of field investigations evidenced a very high prevalence of GHPV infections in French geese, largely associated with healthy carriage.
Fichier non déposé
hal-02646021 , version 1 (29-05-2020)
  • HAL Id : hal-02646021 , version 1
  • PRODINRA : 259828
  • PUBMED : 24597124
  • WOS : 000333275100013
Olivier Léon, Léni Corrand, Tran Ngoc Bich, Odile Le Minor, Mylène Lemaire, et al.. Goose hemorrhagic polyomavirus detection in geese using real-time PCR assay. Avian diseases, 2013, 57 (4), pp.797-799. ⟨hal-02646021⟩
6 Consultations
0 Téléchargements
