Sign choices in the AGM for genus two theta constants - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
Existing algorithms to compute genus 2 theta constants in quasi-linear time use Borchardt sequences, an analogue of the arithmetic-geometric mean for four complex numbers. In this paper, we show that these Borchardt sequences are given by good choices of square roots only, as in the genus 1 case. This removes the sign indeterminacies in the algorithm without relying on numerical integration.
dupont.pdf (244.58 Ko) Télécharger le fichier
hal-02967220 , version 1 (14-10-2020)
hal-02967220 , version 2 (09-10-2022)
Jean Kieffer. Sign choices in the AGM for genus two theta constants. 2020. ⟨hal-02967220v1⟩
106 Consultations
79 Téléchargements
