Evaluating modular equations for abelian surfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
We design algorithms to efficiently evaluate modular equations of Siegel and Hilbert type for abelian surfaces over number fields using complex approximations. Their output can be made provably correct if an explicit description of the associated graded ring of modular forms over Z is known; this includes the Siegel case, and the Hilbert case for the quadratic fields of discriminant 5 and 8. Our algorithms also apply to finite fields via lifting.
evaluation.pdf (410.08 Ko) Télécharger le fichier
hal-02971326 , version 1 (19-10-2020)
hal-02971326 , version 2 (03-03-2022)
Jean Kieffer. Evaluating modular equations for abelian surfaces. 2020. ⟨hal-02971326v2⟩
134 Consultations
73 Téléchargements
