Sacrum osteotomy to change pelvic parameters: Surgical technique and 3D modeling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Orthopaedics & Traumatology: Surgery & Research Année : 2020
Purpose Some clinical situations, such as great sagittal imbalance, high-grade isthmic spondylolisthesis or sacral malunion could require a sacral osteotomy to decrease pelvic parameters, horizontalize the sacrum or correct sacral malunion. Here is described a novel technique to perform a sacral osteotomy to decrease pelvic parameters with a lumbo-pelvic construct, with first a sacral slope decrease, then a pelvic tilt decrease. Methods Simulations have been performed using tridimensional reconstructions of the lumbar spine and pelvis, made from CT-scan images of a healthy individual. A cadaveric study has then been performed. Results 3D modeling exhibited linear relationship between osteotomy angle and pelvic incidence correction, through multiple simulations with 1° increment. Cadaveric study demonstrated feasibility. Conclusion This preliminary work shows that this technique is efficient to decrease pelvic parameters. A linear relationship has been exhibited between osteotomy angle and PI decrease, as per the following formula: osteotomy angle = PI change/0.84. Previous article in issue
Manuscript anglais.pdf (676.17 Ko) Télécharger le fichier
hal-03023233 , version 1 (25-11-2020)
Marc Khalife, Pascal Khalife, Hugues Pascal-Moussellard. Sacrum osteotomy to change pelvic parameters: Surgical technique and 3D modeling. Orthopaedics & Traumatology: Surgery & Research, 2020, 106 (6), pp. 1227-1232. ⟨10.1016/j.otsr.2020.05.010⟩. ⟨hal-03023233⟩
31 Consultations
49 Téléchargements
