On FGLM Algorithms with Tate Algebras - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Tate introduced in [Ta71] the notion of Tate algebras to serve, in the context of analytic geometry over the-adics, as a counterpart of polynomial algebras in classical algebraic geometry. In [CVV19, CVV20] the formalism of Gröbner bases over Tate algebras has been introduced and advanced signature-based algorithms have been proposed. In the present article, we extend the FGLM algorithm of [FGLM93] to Tate algebras. Beyond allowing for fast change of ordering, this strategy has two other important benefits. First, it provides an efficient algorithm for changing the radii of convergence which, in particular, makes effective the bridge between the polynomial setting and the Tate setting and may help in speeding up the computation of Gröbner basis over Tate algebras. Second, it gives the foundations for designing a fast algorithm for interreduction, which could serve as basic primitive in our previous algorithms and accelerate them significantly.
tate_fglm.pdf (253.04 Ko) Télécharger le fichier
hal-03133590 , version 1 (08-02-2021)
Xavier Caruso, Tristan Vaccon, Thibaut Verron. On FGLM Algorithms with Tate Algebras. International Symposium on Symbolic and Algebraic Computation — ISSAC 2021, Jul 2021, Virtual event, Russia. ⟨hal-03133590⟩
90 Consultations
76 Téléchargements
