Mitigating vulnerability windows with hypervisor transplant - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The vulnerability window of a hypervisor regarding a given security flaw is the time between the identification of the flaw and the integration of a correction/patch in the running hypervisor. Most vulnerability windows, regardless of severity, are long enough (several days) that attackers have time to perform exploits. Nevertheless, the number of critical vulnerabilities per year is low enough to allow an exceptional solution. This paper introduces hypervisor transplant, a solution for addressing vulnerability window of critical flaws. It involves temporarily replacing the current datacenter hypervisor (e.g., Xen) which is subject to a critical security flaw, by a different hypervisor (e.g., KVM) which is not subject to the same vulnerability. We build HyperTP, a generic framework which combines in a unified way two approaches: in-place server micro-rebootbased hypervisor transplant (noted InPlaceTP) and live VM migration-based hypervisor transplant (noted MigrationTP). We describe the implementation of HyperTP and its extension for transplanting Xen with KVM and vice versa. We also show that HyperTP is easy to integrate with the OpenStack cloud computing platform. Our evaluation results show that HyperTP delivers satisfactory performance: (1) MigrationTP takes the same time and impacts virtual machines (VMs) with the same performance degradation as normal live migration. (2) the downtime imposed by InPlaceTP on VMs is in the same order of magnitude (1.7 seconds for a VM with 1 vCPU and 1 GB of RAM) as in-place upgrade of homogeneous hypervisors based on server micro-reboot. CCS Concepts • Security and privacy → Virtualization and security. ACM acknowledges that this contribution was authored or co-authored by an employee, contractor or affiliate of a national government. As such, the Government retains a nonexclusive, royalty-free right to publish or reproduce this article, or to allow others to do so, for Government purposes only.
HyperTP__A_unified_approach_for_hypervisor_transplant_in_datacenters(2).pdf (1.43 Mo) Télécharger le fichier
hal-03183856 , version 1 (30-03-2021)
Dinh Ngoc Tu, Boris Teabe, Alain Tchana, Gilles Muller, Daniel Hagimont. Mitigating vulnerability windows with hypervisor transplant. EuroSys 2021 - European Conference on Computer Systems, Apr 2021, Edinburgh / Virtual, United Kingdom. pp.1-14, ⟨10.1145/3447786.3456235⟩. ⟨hal-03183856⟩
468 Consultations
443 Téléchargements
