SYNOP Data Evaluation Using FAIR Maturity Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2021
SYNOP dataset is one of the open meteorological datasets privided by Météo-France on its data portal. The dataset includes observation data from international surface observation messages circulating on the Global Telecommunication System (GTS) of the World Meteorological Organization (WMO) . The choice of this dataset is motivated by the fact that these data are open and free, they concern several atmospheric parameters measured (temperature, humidity, wind direction and force, atmospheric pressure, precipitation height, etc.). These parameters are important for many scientific studies, particularly because SYNOP dataset are published by all WMO member states. SYNOP data is published as open data.
FAIR_evaluation_before_after.pdf (515.47 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-03197115 , version 1 (13-04-2021)
  • HAL Id : hal-03197115 , version 1
Amina Annane, Mouna Kamel, Cassia Trojahn, Nathalie Aussenac-Gilles, Catherine Comparot, et al.. SYNOP Data Evaluation Using FAIR Maturity Model. [Research Report] IRIT/RR--2021--03--FR, IRIT - Institut de Recherche en Informatique de Toulouse. 2021. ⟨hal-03197115⟩
218 Consultations
211 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
