Celestial diamonds: conformal multiplets in celestial CFT - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Journal Articles Journal of High Energy Physics Year : 2021
We examine the structure of global conformal multiplets in 2D celestial CFT. For a 4D bulk theory containing massless particles of spin s = $ \left\{0,\frac{1}{2},1,\frac{3}{2},2\right\} $ we classify and construct all SL(2,ℂ) primary descendants which are organized into ‘celestial diamonds’. This explicit construction is achieved using a wavefunction-based approach that allows us to map 4D scattering amplitudes to celestial CFT correlators of operators with SL(2,ℂ) conformal dimension ∆ and spin J. Radiative conformal primary wavefunctions have J = ±s and give rise to conformally soft theorems for special values of ∆ ∈ $ \frac{1}{2}\mathbb{Z} $. They are located either at the top of celestial diamonds, where they descend to trivial null primaries, or at the left and right corners, where they descend both to and from generalized conformal primary wavefunctions which have |J| ≤ s. Celestial diamonds naturally incorporate degeneracies of opposite helicity particles via the 2D shadow transform relating radiative primaries and account for the global and asymptotic symmetries in gauge theory and gravity.
JHEP11(2021)072.pdf (1.09 Mo) Télécharger le fichier
Origin : Publisher files allowed on an open archive
Dates and versions
hal-03235641 , version 1 (02-05-2024)
Identifiers
Cite
Sabrina Pasterski, Andrea Puhm, Emilio Trevisani. Celestial diamonds: conformal multiplets in celestial CFT. Journal of High Energy Physics, 2021, 11, pp.072. ⟨10.1007/JHEP11(2021)072⟩. ⟨hal-03235641⟩
36 View
0 Download
Share
