Optimized GSE Packet Scheduling over DVB-S2 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The evolution of satellite communication towards packet-based communication and the adoption of modern physical layer techniques, such as Adaptive Coding and Modulation, raise new issues, brought by this variability, for scheduling algorithms. This paper addresses the problem of GSE packets scheduling over DVB-S2 with QoS support by adopting a utility-based scheduling strategy. Utility functions are considered as a mean to encompass parameters from several layers into a single scheduling process. By making use of a first-order approximation, a low complexity scheduling algorithm is derived from the utility functions optimization problem, adaptable to a wide range of functions. The algorithm determines the characteristics of the next BBFrame to be send, and which GSE packets it should contain. We focus particularly on delay as a joint metric to represent QoS requirements, and assess the performance of our algorithm and the relevance of our assumptions using comparative simulations.
Fichier non déposé
hal-03246617 , version 1 (02-06-2021)
Jean-Baptiste Dupé, Emmanuel Chaput, Cédric Baudoin, Caroline Bes, Arnaud Deramecourt, et al.. Optimized GSE Packet Scheduling over DVB-S2. IEEE Global Communications Conference (GLOBECOM 2014), Dec 2014, Austin, TX, United States. pp.2856--2561, ⟨10.1109/GLOCOM.2014.7037241⟩. ⟨hal-03246617⟩
28 Consultations
0 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
