Distributed Evaluation of Graph Queries using Recursive Relational Algebra - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
Pierre Genevès
Nabil Layaïda
We present a system called Dist-µ-RA for the distributed evaluation of recursive graph queries. Dist-µ-RA builds on the recursive relational algebra and extends it with evaluation plans suited for the distributed setting. The goal is to offer expressivity for high-level queries while providing efficiency at scale and reducing communication costs. Experimental results on both real and synthetic graphs show the effectiveness of the proposed approach compared to existing systems.
paper.pdf (1.4 Mo) Télécharger le fichier
hal-03295445 , version 1 (22-07-2021)
hal-03295445 , version 2 (24-11-2021)
hal-03295445 , version 3 (07-10-2022)
Paternité
Sarah Chlyah, Pierre Genevès, Nabil Layaïda. Distributed Evaluation of Graph Queries using Recursive Relational Algebra. 2022. ⟨hal-03295445v3⟩
168 Consultations
223 Téléchargements
