A reconstruction of Fincke's trigonometric tables (1583) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2021
This document gives modern reconstructions of Thomas Fincke (1561-1656)'s trigonometric tables published in 1583. These tables are based on those of Reinhold and the secants were computed by Fincke.
fincke1583doc.pdf (1.11 Mo) Télécharger le fichier
hal-03330599 , version 1 (01-09-2021)
  • HAL Id : hal-03330599 , version 1
Denis Roegel. A reconstruction of Fincke's trigonometric tables (1583). [Research Report] LORIA (Université de Lorraine, CNRS, INRIA). 2021. ⟨hal-03330599⟩
26 Consultations
511 Téléchargements
