Computation of Optimal Transport with Finite Volumes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
We construct Two-Point Flux Approximation (TPFA) finite volume schemes to solve the quadratic optimal transport problem in its dynamic form, namely the problem originally introduced by Benamou and Brenier. We show numerically that these type of discretizations are prone to form instabilities in their more natural implementation, and we propose a variation based on nested meshes in order to overcome these issues. Despite the lack of strict convexity of the problem, we also derive quantitative estimates on the convergence of the method, at least for the discrete potential and the discrete cost. Finally, we introduce a strategy based on the barrier method to solve the discrete optimization problem.
OT_IPM.pdf (1.09 Mo) Télécharger le fichier
hal-03348217 , version 1 (30-11-2020)
hal-03348217 , version 2 (07-01-2021)
hal-03348217 , version 3 (28-08-2021)
hal-03348217 , version 4 (17-09-2021)
Andrea Natale, Gabriele Todeschi. Computation of Optimal Transport with Finite Volumes. 2020. ⟨hal-03348217v1⟩
228 Consultations
133 Téléchargements
