A scalable method for the analysis of networked linear systems with decentralized sampled-data control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Robust and Nonlinear Control Année : 2021
In this paper, the stability analysis problem of networked linear systems with decentralized sampled-data controllers is considered. The networks under consideration are composed of interconnected identical systems. A dissipativity-based approach is utilized to analyze stability, grounded in an interconnection interpretation. A structure exploiting and scalable approach is employed to derive a sufficient stability condition for large-scale linear systems, which is independent of the number of subsystems. In the analysis, the effects of uncertainty on the system models, which include uncertainties that render the coupled systems non-identical, aperiodic sampling, and a switching network topology, are taken into account. Numerical examples are presented to demonstrate the main result and simulate the sampled-data system.
SwitchedNetwork_LTI-LPV-8-FinalAuthorVer.pdf (452.55 Ko) Télécharger le fichier
hal-03364712 , version 1 (04-10-2021)
Deesh Dileep, Christophe Fiter, Laurentiu Hetel, Wim Michiels. A scalable method for the analysis of networked linear systems with decentralized sampled-data control. International Journal of Robust and Nonlinear Control, 2021, ⟨10.1002/rnc.5811⟩. ⟨hal-03364712⟩
61 Consultations
11 Téléchargements
