Application of Motion-Based Visual Servoing to Target Tracking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The International Journal of Robotics Research Année : 2001
In this paper, the classical task of mobile target tracking using a pan-and-tilt camera is considered. The authors use recent results in motion-based visual servoing to deal with complex targets for which shape and texture are unknown. The first method consists of design- ing a control law directly from the estimated image motion. This leads to the computation of the pan-and-tilt acceleration necessary to reduce the tracking error. A second method, more efficient for target tracking, consists of retrieving the target position in the im- age from its estimated motion. This leads to classical image-based visual servoing. For both methods, experimental results obtained at video rate are presented and discussed.
ij1187.pdf (567.04 Ko) Télécharger le fichier
hal-03396150 , version 1 (22-10-2021)
  • HAL Id : hal-03396150 , version 1
Armel Crétual, François Chaumette. Application of Motion-Based Visual Servoing to Target Tracking. The International Journal of Robotics Research, 2001, 20 (11), pp.878-890. ⟨hal-03396150⟩
22 Consultations
75 Téléchargements
