Stability of Neural-Network Based Train Cruise Advisory Control with Aperiodical Measurements - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, a neural-network based driver advisory train cruise control system is considered. The controller assists the train driver with advisory signals by considering train and driver's actual state information (attention and fatigue) measured by dedicated sensors. Considering delays in sensor measurements, this paper aims to assess closed-loop stability of driver-in-the-loop advisory train cruise control. For this purpose, the driver model is considered as a time-varying system, the train model includes rolling and aerodynamic resistance forces and the advisory control is considered to be a sampled-data based three layer multi-layer perceptron. Further, the aperiodic measurement problem is approached as stability analysis of time-varying delayed system. Based on recent developments on the design of augemented Lyapunov Krasovskii Functional (LKF) using Bessel-Legendre inequality for time-varying delays, sufficiency conditions for the existence of L2 stability of the driver-train system in terms of solvable Linear Matrix Inequalities are provided. Further a case study is presented to illustrate the effectiveness of the proposed method.
1-s2.0-S240589632101418X-main.pdf (1.16 Mo) Télécharger le fichier
Origine : Publication financée par une institution
Licence : CC BY NC ND - Paternité - Pas d'utilisation commerciale - Pas de modification
hal-03407136 , version 1 (27-06-2022)
Ayush Kumar Jain, Denis Berdjag, Christophe Fiter, Philippe Polet. Stability of Neural-Network Based Train Cruise Advisory Control with Aperiodical Measurements. 4th IFAC Conference on Embedded Systems, Computational Intelligence and Telematics in Control CESCIT 2021, Jul 2021, Valenciennes, France. pp.92-97, ⟨10.1016/j.ifacol.2021.10.016⟩. ⟨hal-03407136⟩
38 Consultations
22 Téléchargements
