ECM And The Elliott-Halberstam Conjecture For Quadratic Fields - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
The complexity of the elliptic curve method of factorization (ECM) is proven under the celebrated conjecture of existence of smooth numbers in short intervals. In this work we tackle a different version of ECM which is actually much more studied and implemented, especially because it allows us to use ECM-friendly curves. In the case of curves with complex multiplication (CM) we replace the heuristics by rigorous results conditional to the Elliott-Halberstam (EH) conjecture. The proven results mirror recent theorems concerning the number of primes p such thar p − 1 is smooth. To each CM elliptic curve we associate a value which measures how ECM-friendly it is. In the general case we explore consequences of a statement which translated EH in the case of elliptic curves.
article.pdf (510.98 Ko) Télécharger le fichier
hal-03485435 , version 1 (17-12-2021)
hal-03485435 , version 2 (24-05-2022)
hal-03485435 , version 3 (22-12-2022)
hal-03485435 , version 4 (17-01-2023)
Razvan Barbulescu, Florent Jouve. ECM And The Elliott-Halberstam Conjecture For Quadratic Fields. 2022. ⟨hal-03485435v3⟩
140 Consultations
104 Téléchargements
