Superquantile-based learning: a direct approach using gradient-based optimization. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Signal Processing Systems Année : 2022
We consider a formulation of supervised learning that endows models with robustness to distributional shifts from training to testing. The formulation hinges upon the superquantile risk measure, also known as the conditional value-at-risk, which has shown promise in recent applications of machine learning and signal processing. We show that, thanks to a direct smoothing of the superquantile function, a superquantile-based learning objective is amenable to gradient-based optimization, using batch optimization algorithms such as gradient descent or quasi-Newton algorithms, or using stochastic optimization algorithms such as stochastic gradient algorithms. A companion software SPQR implements in Python the algorithms described and allows practitioners to experiment with superquantile-based supervised learning.
main.pdf (625.31 Ko) Télécharger le fichier
hal-03505745 , version 1 (31-12-2021)
Yassine Laguel, Jérôme Malick, Zaid Harchaoui. Superquantile-based learning: a direct approach using gradient-based optimization.. Journal of Signal Processing Systems, 2022. ⟨hal-03505745⟩
Collections
UGA CNRS TDS-MACS
29 Consultations
54 Téléchargements
