Simulation of eddy current testing of steam generator tubes with wears and secondary side magnetite deposits - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Steam Generators (SGs) tubes of Pressurized Water Reactors are prone to degradations and are periodically inspected with Eddy current techniques. SGs provide a safety barrier between the radioactive primary side and the non-radioactive secondary side. Historically, a major degradation issue was stress corrosion cracking of tubes made of alloy 600. In modern SGs, a better resistance to stress corrosion cracking is observed with the replacement of alloy 600 by alloy 690. However, this alloy does not prevent tubes from wear at supports location or wear resulting from fretting with loose parts. Long-term operation of SGs leads also to non-volatile species accumulation in the secondary side of the SGs, mainly magnetite. Magnetite deposits may build-up as dense and solid material on the top of the tubesheet (hard sludge) but also in the flow slots of tubes support plates and therefore modify the general flow pattern and velocity of the secondary fluid. This effect has detrimental effects on the safe operation of SGs. The ratio of the flow slots clogging-up need therefore to be assessed.The development of an ECT simulation model to address tube wear and magnetite deposit in SGs is presented. This model is based on the CIVA NDT platform. The bobbin coil signal is simulated and its performances for tube wear and magnetite deposits evaluation are discussed.
Modeling_ECT_INSIGHT_Final.pdf (922.75 Ko) Télécharger le fichier
Licence : CC BY - Paternité
hal-03665557 , version 1 (27-10-2023)
Paternité
Thierry Sollier, Jean Marc Decitre, Audrey Vigneron, Edouard Demaldent. Simulation of eddy current testing of steam generator tubes with wears and secondary side magnetite deposits. 58th Annual Conference of the British Institute of Non-Destructive Testing (NDT 2019), Sep 2019, Telford, United Kingdom. pp.73-78, ⟨10.1784/insi.2022.64.2.73⟩. ⟨hal-03665557⟩
101 Consultations
68 Téléchargements
