Sharp Feature Consolidation from Raw 3D Point Clouds via Displacement Learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Aided Geometric Design Année : 2023
Tong Zhao
  • Fonction : Auteur
  • PersonId : 1104023
Pierre Alliez
Florent Lafarge
  • Fonction : Auteur
  • PersonId : 833647
Detecting sharp features in raw point clouds is an essential step in designing efficient priors in several 3D Vision applications. This paper presents a deep learning-based approach that learns to detect and consolidate sharp feature points on raw 3D point clouds. We devise a multi-task neural network architecture that identifies points near sharp features and predicts displacement vectors toward the local sharp features. The so-detected points are thus consolidated via relocation. Our approach is robust against noise by utilizing a dynamic labeling oracle during the training phase. The approach is also flexible and can be combined with several popular point-based network architectures. Our experiments demonstrate that our approach outperforms the previous work in terms of detection accuracy measured on the popular ABC dataset. We show the efficacy of the proposed approach by applying it to several 3D Vision tasks.
sharp-detection.pdf (35.62 Mo) Télécharger le fichier
hal-03747150 , version 1 (07-08-2022)
hal-03747150 , version 2 (14-06-2023)
Paternité
Tong Zhao, Mulin Yu, Pierre Alliez, Florent Lafarge. Sharp Feature Consolidation from Raw 3D Point Clouds via Displacement Learning. Computer Aided Geometric Design, 2023, 13, pp.102204. ⟨10.1016/j.cagd.2023.102204⟩. ⟨hal-03747150v1⟩
290 Consultations
39 Téléchargements
