Federated Learning with Heterogeneous Data: A Superquantile Optimization Approach
We present a federated learning framework that is designed to robustly deliver good predictive performance across individual clients with heterogeneous data. The proposed approach hinges upon a superquantile-based learning objective that captures the tail statistics of the error distribution over heterogeneous clients. We present a stochastic training algorithm which interleaves differentially private client reweighting steps with federated averaging steps. The proposed algorithm is supported with finite time convergence guarantees that cover both convex and non-convex settings. Experimental results on benchmark datasets for federated learning demonstrate that our approach is competitive with classical ones in terms of average error and outperforms them in terms of tail statistics of the error.
Machine Learning [stat.ML]
