A Lightweight Joint RIS/BS Configuration Scheme - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The integration of RIS elements in upcoming 6G networks appears a major breakthrough to extend network coverage and capacity. This paper introduces a new link-layer scheme for RIS-enabled communications building on existing models for the physical layer of RIS technologies. The scheme is able to integrate the selection of precoders/beams in a codebook and scheduling of UEs at once. Furthermore, elements for the integration of the proposed scheme in current 3GPP-5G specifications are addressed. The scheduler combines a slow mechanism operating at the downlink OFDMA frame scale with a standard proportional fair scheduler operating at the OFDMA slot scale and accommodating both LOS and non-LOS UEs. We introduce an optimization framework for the proposed scheduler whose performance is hence simulated in a reference scenario. The spectral efficiency figures in our tests confirm a large gain of the scheme against a baseline direct path scheme. Finally, the scheduler optimization permits to achieve a further improvement of 15-20% for non line-of-sight users.
6GNET_2022_Light_weight Joint RIS-BS Configuration Scheme.pdf (419.46 Ko) Télécharger le fichier
hal-03754824 , version 1 (20-08-2022)
  • HAL Id : hal-03754824 , version 1
Antoine Dejonghe, Zwi Altman, Francesco de Pellegrini, Eitan Altman. A Lightweight Joint RIS/BS Configuration Scheme. 6GNet 2022 - 1st International conference on 6G Networking, Jul 2022, Paris, France. ⟨hal-03754824⟩
70 Consultations
47 Téléchargements
