Unleashing GPUs for Network Function Virtualization: an open architecture based on Vulkan and Kubernetes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
General-purpose computing on graphics processing units (GPGPU) is a promising way to speed up computationally intensive network functions, such as performing real-time traffic classification based on machine learning. Recent studies have focused on integrated graphics units and various performance optimizations to address bottlenecks such as latency. However, these approaches tend to produce architecture-specific binaries and lack the orchestration of functions. A complementary effort would be a GPGPU architecture based on standard and open components, which allows the creation of interoperable and orchestrable network functions. This study describes and evaluates such open architecture based on the cross-platform Vulkan API, in which we execute handwritten SPIR-V code as a network function. We also demonstrate a multi-node orchestration approach for our proposed architecture using Kubernetes. We validate our architecture by executing SPIR-V code performing traffic classification with random forest inference. We test this application both on discrete and integrated graphics cards and on x86 and ARM. We find that in all cases the GPUs are faster than the baseline Cython code.
haavisto2021vulkan_HAL.pdf (389.98 Ko) Télécharger le fichier
hal-03793322 , version 1 (30-09-2022)
Juuso Haavisto, Thibault Cholez, Jukka Riekki. Unleashing GPUs for Network Function Virtualization: an open architecture based on Vulkan and Kubernetes. 35th IEEE/IFIP Network Operations and Management Symposium (NOMS 2022), Apr 2022, Budapest, Hungary. pp.1-8, ⟨10.1109/NOMS54207.2022.9789822⟩. ⟨hal-03793322⟩
35 Consultations
226 Téléchargements
