Ensemble classification of video-recorded crowd movements - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ensemble learning methods often improve results in problems addressed by single Machine Learning models. In this work, we apply Ensemble Learning on video-recorded crowd movements. First, we build Ensembles of homogeneous Convolutional Neural Networks (CNN) to compare their performance on the Crowd-11 dataset and show the gain of performance demonstrated by Ensembles compared to single CNN models. Secondly, we evaluate all the possible combinations of these homogeneous Ensembles to build a global Ensemble of heterogeneous models, and we analyze the combination of Ensembles that achieves the best results. Our experiments reveal that Ensemble classification often obtains better results than single models and combining different Ensembles can make the predictions accuracy even better.
ispa2021.pdf (245.75 Ko) Télécharger le fichier
hal-03800450 , version 1 (29-11-2022)
Mounir Bendali-Braham, Jonathan Weber, Germain Forestier, Lhassane Idoumghar, Pierre-Alain Muller. Ensemble classification of video-recorded crowd movements. International Symposium on Image and Signal Processing and Analysis (ISPA), Sep 2021, Zagreb, Croatia. pp.152-158, ⟨10.1109/ISPA52656.2021.9552129⟩. ⟨hal-03800450⟩
Collections
SITE-ALSACE IRIMAS
14 Consultations
22 Téléchargements
