Evaluating Surgical Skills from Kinematic Data Using Convolutional Neural Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
The need for automatic surgical skills assessment is increasing, especially because manual feedback from senior surgeons observing junior surgeons is prone to subjectivity and time consuming. Thus, automating surgical skills evaluation is a very important step towards improving surgical practice. In this paper, we designed a Convolutional Neural Network (CNN) to evaluate surgeon skills by extracting patterns in the surgeon motions performed in robotic surgery. The proposed method is validated on the JIGSAWS dataset and achieved very competitive results with 100% accuracy on the suturing and needle passing tasks. While we leveraged from the CNNs efficiency, we also managed to mitigate its black-box effect using class activation map. This feature allows our method to automatically highlight which parts of the surgical task influenced the skill prediction and can be used to explain the classification and to provide personalized feedback to the trainee.
miccai2018.pdf (2.43 Mo) Télécharger le fichier
hal-03800569 , version 1 (06-10-2022)
Hassan Ismail Fawaz, Germain Forestier, Jonathan Weber, Lhassane Idoumghar, Pierre-Alain Muller. Evaluating Surgical Skills from Kinematic Data Using Convolutional Neural Networks. Medical Image Computing and Computer Assisted Intervention (MICCAI), Sep 2018, Granada, Spain. pp.214 - 221, ⟨10.1007/978-3-030-00937-3_25⟩. ⟨hal-03800569⟩
Collections
SITE-ALSACE IRIMAS
6 Consultations
29 Téléchargements
