Sampled-data Distributed Control for Homo-directional Linear Hyperbolic System with Spatially Sampled State Measurements - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2022
This paper addresses the stability analysis problem for a class of linear hyperbolic systems with distributed controllers sampled in space and time. First, the considered system is recast in an equivalent form with a continuous time control loop and operators representing the discretization errors (spatio-temporal sampling errors). Then with the help of the Lyapunov-Razumikhin approach, the Rε-stability of the proposed linear hyperbolic systems of balance laws is verified via sufficient conditions. At last, the proposed method is illustrated numerically.
Automatica.pdf (503.4 Ko) Télécharger le fichier
hal-03822880 , version 1 (20-10-2022)
Xinyong Wang, Ying Tang, Christophe Fiter, Laurentiu Hetel. Sampled-data Distributed Control for Homo-directional Linear Hyperbolic System with Spatially Sampled State Measurements. Automatica, 2022, ⟨10.1016/j.automatica.2022.110183⟩. ⟨hal-03822880⟩
46 Consultations
33 Téléchargements
