Insights into the potential for mutualistic and harmful host‐microbe interactions affecting brown alga freshwater acclimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Molecular Ecology Année : 2022
Microbes can modify their hosts' stress tolerance, thus potentially enhancing their ecological range. An example of such interactions is Ectocarpus subulatus, one of the few freshwater-tolerant brown algae. This tolerance is partially due to its (un)cultivated microbiome. We investigated this phenomenon by modifying the microbiome of laboratory-grown E. subulatus using mild antibiotic treatments, which affected its ability to grow in low salinity. Low salinity acclimation of these algal-bacterial associations was then compared. Salinity significantly impacted bacterial and viral gene expression, albeit in different ways across algal-bacterial communities. In contrast, gene expression of the host and metabolite profiles were affected almost exclusively in the freshwater-intolerant algal-bacterial communities. We found no evidence of bacterial protein production that would directly improve algal stress tolerance. However, vitamin K synthesis is one possible bacterial service missing specifically in freshwater-intolerant cultures in low salinity. In this condition, we also observed a relative increase in bacterial transcriptomic activity and the induction of microbial genes involved in the biosynthesis of the autoinducer AI-1, a quorum-sensing regulator. This could have resulted in dysbiosis by causing a shift in bacterial behavior in the intolerant algal-bacterial community. Together, these results provide two promising hypotheses to be examined by future targeted experiments. Although they apply only to the specific study system, they offer an example of how bacteria may impact their host's stress response.
Molecular Ecology - 2022 - KleinJan - Insights into the potential for mutualistic and harmful host microbe interactions.pdf (1.44 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-03868898 , version 1 (24-11-2022)
Paternité
Hetty Kleinjan, Clémence Frioux, Gianmaria Califano, Méziane Aite, Enora Fremy, et al.. Insights into the potential for mutualistic and harmful host‐microbe interactions affecting brown alga freshwater acclimation. Molecular Ecology, inPress, 32 (3), pp.703-723. ⟨10.1111/mec.16766⟩. ⟨hal-03868898⟩
102 Consultations
75 Téléchargements
