Set-membership fault detection approach for a class of nonlinear networked control systems with communication delays - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, a Fault Detection (FD) problem for a class of Nonlinear Networked Control Systems (NNCS) in a set-membership framework is investigated. Under the assumption of bounded network-induced delays and process uncertainties (i.e. process disturbances and measurement noises), a residual generator is constructed based on a set-membership estimation-based predictor approach. Finally, a numerical example illustrating the performances of the proposed method is given.
Final_ACD22_0029.pdf (391.04 Ko) Télécharger le fichier
hal-03892229 , version 1 (09-12-2022)
  • HAL Id : hal-03892229 , version 1
Afef Najjar, Jean-Christophe Ponsart. Set-membership fault detection approach for a class of nonlinear networked control systems with communication delays. 16th European Workshop on Advanced Control and Diagnosis, ACD 2022, Nov 2022, Nancy, France. ⟨hal-03892229⟩
22 Consultations
18 Téléchargements
