Computing isogenies between finite Drinfeld modules - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
We prove that isogenies between Drinfeld modules over a finite field can be computed in polynomial time. This breaks Drinfeld analogs of isogeny-based cryptosystems.
2022-438.pdf (218.33 Ko) Télécharger le fichier
hal-03941045 , version 1 (16-01-2023)
  • HAL Id : hal-03941045 , version 1
Benjamin Wesolowski. Computing isogenies between finite Drinfeld modules. 2022. ⟨hal-03941045⟩
47 Consultations
24 Téléchargements
