Capturing Public Knowledge and Awareness From Data Models and Policies to Build Research Links Between EU and US Ocean Research - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2022
Capturar el conocimiento y la sensibilización pública a partir de modelos de datos y políticas para construir vínculos de investigación entre la investigación oceánica de la UE y EE. UU.
Capturer les connaissances et la sensibilisation du public à partir de modèles de données et de politiques pour établir des liens de recherche entre la recherche océanique de l'UE et des États-Unis
Capturing the complexities of the common research challenges both the EU and US face is a goal of public policies when using as a framework the global risks posed by marine litter, particularly plastics. To turn the theory of industry 5.0 into practice, the full participation of all actors concerned with the use of ocean space could be useful to design research links between the initiatives launched by the European Commission and the American Federal Government. The chapter indicates that while a common data model is defined by the US Federal Agency specialized in dealing with the marine environment, the European focus is on interoperability between State Members. The research raises awareness on the marine plastic problem by recognizing that ocean literacy is critical to educate the public. Moreover, an examination concerning the discovery of these data (where this kind of marine litter data can be found), their access (confidentiality, intellectual propriety rights), and use (by the public sector, fisheries sector) are also offered in this study.
Captar las complejidades de los desafíos de investigación comunes que enfrentan tanto la UE como los EE. UU. es un objetivo de las políticas públicas cuando se utiliza como marco los riesgos globales que plantean los desechos marinos, particularmente los plásticos. Para llevar la teoría de la industria 5.0 a la práctica, la plena participación de todos los actores preocupados por el uso del espacio oceánico podría ser útil para diseñar vínculos de investigación entre las iniciativas lanzadas por la Comisión Europea y el Gobierno Federal estadounidense. El capítulo indica que, si bien la Agencia Federal de los EE. UU. especializada en el tratamiento del medio ambiente marino define un modelo de datos común, el enfoque europeo se centra en la interoperabilidad entre los Estados miembros. La investigación crea conciencia sobre el problema del plástico marino al reconocer que la alfabetización oceánica es fundamental para educar al público. Además, en este estudio también se ofrece un examen sobre el descubrimiento de estos datos (donde se pueden encontrar este tipo de datos sobre basura marina), su acceso (confidencialidad, derechos de propiedad intelectual) y uso (por el sector público, sector pesquero).
Saisir les complexités des défis de recherche communs auxquels l'UE et les États-Unis sont confrontés est un objectif des politiques publiques lorsqu'elles utilisent comme cadre les risques mondiaux posés par les déchets marins, en particulier les plastiques. Pour concrétiser la théorie de l'industrie 5.0, la pleine participation de tous les acteurs concernés par l'utilisation de l'espace océanique pourrait être utile pour concevoir des liens de recherche entre les initiatives lancées par la Commission européenne et le gouvernement fédéral américain. Le chapitre indique qu'alors qu'un modèle de données commun est défini par l'Agence fédérale américaine spécialisée dans le traitement de l'environnement marin, l'accent européen est mis sur l'interopérabilité entre les États membres. La recherche sensibilise au problème du plastique marin en reconnaissant que la connaissance des océans est essentielle pour éduquer le public. De plus, un examen concernant la découverte de ces données (où ce type de données sur les déchets marins peut être trouvé), leur accès (confidentialité, droits de propriété intellectuelle) et leur utilisation (par le secteur public, le secteur de la pêche) sont également proposés dans cette étude.
Fichier non déposé
hal-03988227 , version 1 (14-02-2023)
Enrique Wulff. Capturing Public Knowledge and Awareness From Data Models and Policies to Build Research Links Between EU and US Ocean Research. Handbook of Research on Technological Advances of Library and Information Science in Industry 5.0, IGI Global, pp.415-429, 2022, Advances in Library and Information Science, 9781668447550. ⟨10.4018/978-1-6684-4755-0.ch021⟩. ⟨hal-03988227⟩
27 Consultations
0 Téléchargements
