The Important Electron Impact Collision Cross Sections with Methane - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Djilali Benyoucef
Rachid Taleb
  • Fonction : Auteur
  • PersonId : 945944
The electrical discharge plasma in methane is used in many fields of technology and the knowledge of the electron impact cross sections with the molecule of this gas is necessary for the modeling, which represents a good tool for understanding this phenomenon. The main object of this work is a finding the important electron impact cross sections with the methane molecule through the reviewing the theoretical and measured data found in the literature.
Gadoum ICEEB.pdf (261.34 Ko) Télécharger le fichier
hal-03995954 , version 1 (19-02-2023)
Abdelatif Gadoum, Djilali Benyoucef, Rachid Taleb. The Important Electron Impact Collision Cross Sections with Methane. Second International Conference on Electrical Engineering ICEEB'18, Dec 2018, Biskra, Algeria. ⟨hal-03995954⟩
49 Consultations
20 Téléchargements
