Adaptive Denoising of Signals with Local Shift-Invariant Structure - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We discuss the problem of adaptive discrete-time signal denoising in the situation where the signal to be recovered admits a ``linear oracle'' - an unknown linear estimate that takes the form of convolution of observations with a time-invariant filter. It was shown by Juditsky and Nemirovski (2009) that when the $\ell_2$-norm of the oracle filter is small enough, such oracle can be ``mimicked'' by an efficiently computable \textit{adaptive} estimate of the same structure with the observation-driven filter. The filter in question was obtained as a solution to the optimization problem in which the $\ell_\infty$-norm of the Discrete Fourier Transform (DFT) of the estimation residual is minimized under constraint on the $\ell_1$-norm of the filter DFT. In this paper, we discuss a new family of adaptive estimates which rely upon minimizing the $\ell_2$-norm of the estimation residual. We show that such estimators possess better statistical properties than those based on~$\ell_\infty$-fit; in particular, under the assumption of \textit{approximate shift-invariance} we prove oracle inequalities for their $\ell_2$-loss and improved bounds for $\ell_2$- and pointwise losses. We also study the relationship of the approximate shift-invariance assumption with the signal simplicity introduced by Juditsky and Nemirovski (2009), and discuss the application of the proposed approach to harmonic oscillation denoising.
harchaouietal.pdf (553.63 Ko) Télécharger le fichier
hal-04037260 , version 1 (22-03-2023)
Paternité
  • HAL Id : hal-04037260 , version 1
Zaid Harchaoui, Anatoli B. Juditsky, Arkadi Nemirovski, Dmitrii M. Ostrovskii. Adaptive Denoising of Signals with Local Shift-Invariant Structure. Festschrift in Honor of Vladimir Spokoiny, Nov 2019, Berlin, Germany. ⟨hal-04037260⟩
17 Consultations
10 Téléchargements
