Programming dynamic reconfigurable systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal on Software Tools for Technology Transfer Année : 2021
Rim El Ballouli
  • Fonction : Auteur
Saddek Bensalem
  • Fonction : Auteur
Marius Bozga
  • Fonction : Auteur
Joseph Sifakis
  • Fonction : Auteur
DR-BIP is an extension of the BIP component framework intended for programming reconfigurable systems encompassing various aspects of dynamism. It relies on architectural motifs to structure the architecture of a system and to coordinate its reconfiguration at runtime. An architectural motif defines a set of interacting components that evolve according to reconfiguration rules. With DR-BIP, the dynamism can be captured as the interplay of dynamic changes in three independent directions 1) the organization of interactions between instances of components in a given configuration; 2) the reconfiguration mechanisms allowing creation/deletion of components and management of their interaction according to a given architectural motif; 3) the migration of components between predefined architectural motifs which characterizes dynamic execution environments. The paper lays down the formal foundation of DR-BIP, illustrates its expressiveness on few examples and discusses avenues for dynamic reconfigurable system design.
main.pdf (494.07 Ko) Télécharger le fichier
hal-04106085 , version 1 (25-05-2023)
Rim El Ballouli, Saddek Bensalem, Marius Bozga, Joseph Sifakis. Programming dynamic reconfigurable systems. International Journal on Software Tools for Technology Transfer, 2021, 23 (5), pp.701-719. ⟨10.1007/s10009-020-00596-7⟩. ⟨hal-04106085⟩
10 Consultations
27 Téléchargements
